Print at Jul 27, 2026, 5:55:21 PM
Posted by Puybaret at Mar 14, 2018, 10:26:42 AM
Re: zoom for HTML5 tool file is weak compared to program zoom
It's great that you could achieve it by yourself smile
As you finally found out, setSelectedItems method takes an array of objects (furniture, walls or other objects stored in a Home instance) and not an array of numbers or quoted numbers.
How can I tell when the "Home" is loaded?
The home loading process can be tracked in the onprogression callback. Just change the existing callback in the condition part === HomeRecorder.READING_HOME. Doing so will be much safer than programming a timer with a delay that may vary with bandwidth and CPU power.
Thanks for the donation smile
