Print at Aug 21, 2026, 7:33:06 AM
Posted by Puybaret at Nov 4, 2007, 4:39:00 PM
Re: Making a door
Nice door ;-)
First note that the intersection between a wall and a door or a window is based on the bounding box of the door or the window.
Maybe you should add some kind of a thin frame around your door, and set the depth of that surrounding frame in such a way it matches the wall thickness (I used 25 cm or 9.842 inches for that kind of wall).
If you want to, send me your file so I can test it.
