Print at Sep 6, 2026, 2:40:40 AM
Posted by Puybaret at Jan 8, 2018, 12:32:07 PM
Re: Rounding of co-ordinates
The values in cm are rounded to the closest decimal in the user interface, but this value may be different in memory and then in the Home.xml file.
This gives me the opportunity to give a tip about handling precision in Sweet Home 3D: in all the spinner fields that accept decimal numbers, it's possible to enter a value with more decimals that the field displays and these additional decimals won't be forgotten when you confirm your choice.
For example, if you enter an angle of 1.54°, the field will still display 1.5°, but the actual value in memory will be 1.54°.
