Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Can't run application » » » » Post: Re: Can't run application |
Print at Jul 22, 2026, 2:30:19 PM |
| Posted by Puybaret at Aug 13, 2007, 4:13:00 AM |
Re: Can't run application The easiest way to run Sweet Home 3D is with its online JNLP file available at http://sweethome3d.sourceforge.net/SweetHome3D.jnlp . If you want to run it from NetBeans you should run the class com.eteks.sweethome3d.SweetHome3D with the system property java.library.path equal to the lib/windows Sweet Home 3D sub directory (thanks to the Java option -Djava.library.path=path/to/lib/windows). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Jul 22, 2026, 2:30:19 PM |
