Print at Oct 11, 2026, 4:20:41 PM
Posted by ybon at Nov 14, 2017, 8:55:18 PM
Re: 3d View suddenly impossibly slow
Running SH3D after a long period without using it, seems I'm hitting the same issue: it's abnormaly slow.
For example, trying to draw a wall on a new project takes something like 5 seconds.
Sometimes it even takes longer for the wall to be drawn on the drawing area than on the 3D viewer.
I'm running Arch Linux on a Precision 5510, with i5-6300HQ Skylake CPUs, 16Gb of RAM.
Graphic card is a Nvidia GM107GLM (Quadro M1000M).
I've a 4k screen (3840x2160).
I'm running Java through OpenJDK 1.9:
java -version
openjdk version "9"
OpenJDK Runtime Environment (build 9+181)
OpenJDK 64-Bit Server VM (build 9+181, mixed mode)
Java 3D version is 1.6.0.
SH3D version is 5.5.2:
Here is some of my attemps to workaround the situation, but without luck:
- using OpenJDK 8
- java -Dcom.eteks.sweethome3d.j3d.version=1.5.2 -jar SweetHome3D-5.6.jar
- ./javaws SweetHome3D.jnlp
Any idea what more I should try/check to understand/fix the issue?
Thanks for your hints!
Yohan
