Print at Sep 20, 2026, 3:18:42 PM
Posted by Ceciliabr at Oct 10, 2017, 1:33:31 AM
Re: Same image – like night & day - a miracle?
@ enkonyito
This is a "normal" behavior of the renderer.
Ok. That's good to know.
I have noticed some other forms of "unexpected behaviour" that you might interested in:
It seems the wall texture is not rendering like it should when I'm using the Create photo with renderer:
Here with the default renderer:
And here with the Create photo with renderer:
The texture of the ground beneath the cobblestones don't look right. It has some kind of waffle-appearance compared to the image rendered with the default renderer.
I wanted to see if the same happened at daytime:
It seems it did.
And this is with the Create photo with renderer::
And, as you can see, it's not only the walls and the ground texture that are different, the bicycle stand and the football also renders with a different looking texture.
I have the v1.3.2 version of the Create photo with renderer, and my settings for these renderings are the default settings of Q4.
Cec.
