Print at Sep 6, 2026, 4:08:54 AM
Posted by Puybaret at Jun 29, 2017, 7:32:07 PM
Re: real time surface
Adding a CollectionListener<Room> to home will inform you only on new and deleted rooms, as you noticed. If you want to listen to changes to the room points, you'll have to add a PropertyChangeListener on each room (and remove it when the room is deleted), and update your text area when the property name in the event is equal to Room.Property.POINTS.name().
[Please continue this thread in English because you started in English]
