Print at Sep 25, 2026, 2:49:07 AM
Posted by Puybaret at May 30, 2017, 8:25:19 PM
Re: view problem
Thanks for the file which helped me to reproduce your issue. smile
The problem comes from the small walls you drew in some corners as shown in the following image:
As you can see, it creates some walls that may have a null length side, and a part of the program that measures the distance between an object and wall side failed for a side equal to zero.
I fixed this bug and the correction will be available in the next version.
Meanwhile, you should avoid these small walls and connect directly walls while drawing them.
