Print at Jun 19, 2026, 3:13:11 PM
Posted by Puybaret at May 21, 2017, 4:56:29 PM
Re: Open double door needed
Bubblobill, thanks for trying but the faces of the 3D model you proposed are not well oriented when imported in Sweet Home 3D : I guess you forgot to select the option Mesh > Normals > Flip Normals on the mirrored door you created in Blender.
By the way, it's clearly a work derived from the open door available in Sweet Home 3D and the OBJ file should repeat the same license in its header when you redistribute a modified version (OBJ file is a text file, so it's easy to update it). Of course, you can add in this header your name as a contributor.
