Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: calculating outside surface of all walls » » » » Post: Re: calculating outside surface of all walls |
Print at Oct 6, 2026, 8:41:45 AM |
| Posted by okh at May 19, 2017, 7:00:32 PM |
Re: calculating outside surface of all walls And if you want to know the inside of the wall, for, say, insulation? While I do not share bdfd's concerns about the plugin using measurements from the centre of the wall, that is easy enough to adjust for. Nevertheless, put the plugin trough a little test. And while it behaved well on one or two sloping walls with a few cut-outs, it seems to have problems with many walls/openings - at least, I could not get the results I expected (but that may be me). So, I might still use the plugin, but I would double check the result. ok |
Current timezone is GMT Oct 6, 2026, 8:41:45 AM |
