Print at Aug 16, 2026, 12:10:34 AM
Posted by bdfd at May 19, 2017, 12:08:32 PM
Re: calculating outside surface of all walls
Actually, there is an easy way: Plugin #5 ComputeWallsSurface will calculate for you (albeit with some caveats mentioned on plugin download page and discussions such as thread 7516: Calculating the surface of the wall).
If you take into account that it measures the inside of the wall, it should do pretty much what you want if you install the plugin, restart sh3d, select the outer walls and run the plugin from the tools menu.
Good luck with your insulation project.
Great, I didn't know this plugin ! applause
But there is a problem, this plugin calculates surface from the middle of the walls. sad
Platax asks us an outside walls surface... it's not the same ! tongue
So, the lonely solution is manual calculations... crying
See below the demo (height of the walls = 1.0 m) :
See lines and distance with the calulated surface...
