Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to do a vaulted and flat ceiling of a single wall » » » » Post: Re: How to do a vaulted and flat ceiling of a single wall |
Print at Sep 25, 2026, 1:34:05 PM |
| Posted by ltd77 at May 18, 2017, 6:27:07 AM |
Re: How to do a vaulted and flat ceiling of a single wall Hello: I found another way to do this and thought I would share. I created a new level above the current elevation called "ceiling". In this new level, I created the sloped walls that extend upward from the walls of the level below it. One end if the walls are close to zero as I could get (1/8"), and the highest point ended up being 2'10". Then, I created a room in this area, and checked "show ceiling", and unchecked "show floor". Under the "3D View" menu, I also selected "Display all levels", which I had not seen before, which will show the levels above and below from the Virtual Visit feature all together. On the main level I unchecked "show ceiling", so that it will show the sloped ceiling from the level above it. Now, the 3D view looks correct and also the Create Photo feature is drawing in the correct ceiling! Chris |
Current timezone is GMT Sep 25, 2026, 1:34:05 PM |
