Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: error 40 » » » » Post: Re: error 40 |
Print at Sep 21, 2026, 6:35:17 AM |
| Posted by Puybaret at May 3, 2017, 10:22:06 AM |
Re: error 40 The error 40 covers errors that may happen during the export on the server (a little like if the Export to HTML5 plug-in failed). The reason suggested by bdfd is interesting and I should check how to avoid the issue he describes, but in the case of Mike777, it's another issue. The logs on the server report that it's due to a damaged .sh3d file. So please double check if the .sh3d file you submitted can be opened in Sweet Home 3D (maybe you copied it in a different file). I also made some adjustments that could fix your issue (even if I don't believe in this option), so please try again. Then if it still happens, please tell us. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 21, 2026, 6:35:17 AM |
