Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: not showing modifying panels » » » » Post: Re: not showing modifying panels |
Print at Sep 15, 2026, 10:52:49 AM |
| Posted by Nio at Apr 22, 2017, 10:03:02 PM |
Re: not showing modifying panels after when i make wall then I select that wall and go to plan and select modify wall but the box (panel) of modify wall which is appear by clicking (modify wall < plan ) is not showing modify wall panel I mean I can't able to use modify walls also modify furniture , modify room cos the panel (box) is not showing (appearing) but only modify level is working I mean showing its panel and I didn't do base lock and I do everything systematic .. if you still didn't understand ..ask it I will again try to explain you .. |
Current timezone is GMT Sep 15, 2026, 10:52:49 AM |
