Print at Sep 6, 2026, 6:03:06 AM
Posted by sfcfs at Apr 22, 2017, 1:32:15 AM
SH3d 5.4 On MacOS Sierra and Macbook Air not working
Using the Java Web Start application. App opens the Menu appears. However, all of the menu items are grayed out except "Open recent home." When I click one of the plans, nothing happens and application hangs. Cannot quit from menu, but kill the process from terminal.
The Java Console when shown shows a bunch of security warnings:
Insecure property: (com.eteks.sweethome3d.applicationId, SweetHome3D#JavaWebStart) specified in unsigned j
Insecure property: (com.eteks. sweethome3d.deploymentInformation, Java Web Start) specified in unsigned jn
Insecure property: (j3d. rend, jog t) specified in unsigned jnlp file wilt not be set.
Insecure property: (apple.awt.graphics.UseQuartz, true) specified in unsigned jntp file wilt not be set.
Java Web Start 11.131.2.11 x86_64
Using DRE version 1.8.Ø_131-b11 Java Hotspot(TM) 64-Bit Server VM
And then shows an Exception:
Exception in thread "AWT-EventQueue-2" java.lang.ExceptionInInitializerError
at com.eteks.test.VideoPlugin.<init>(VideoPlugin.java:133)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
at java.lang.Class.newInstance(Class.java:442)
at com.eteks.sweethome3d.plugin.PluginManager.getPlugins(Unknown Source)
at com.eteks.sweethome3d.plugin.HomePluginController.getPlugins(Unknown Source)
at com.eteks.sweethome3d.swing.HomePane.<init>(Unknown Source)
at com.eteks.sweethome3d.swing.SwingViewFactory.createHomeView(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController.getView(Unknown Source)
at com.eteks.sweethome3d.HomeFramePane.<init>(Unknown Source)
at com.eteks.sweethome3d.HomeFrameController.getView(Unknown Source)
at com.eteks.sweethome3d.HomeFrameController.displayView(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D$4.collectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(Unknown Source)
at com.eteks.sweethome3d.model.HomeApplication.addHome(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.showDefaultHomeFrame(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D.start(Unknown Source)
at com.eteks.sweethome3d.SweetHome3D$5.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Caused by: java.security.AccessControlException: access denied ("java.util.PropertyPermission" "com.eteks.sweethome3d.resolutionScale" "read")
at java.security.AccessControlContext.checkPermission(AccessControlContext.java:472)
at java.security.AccessController.checkPermission(AccessController.java:884)
at java.lang.SecurityManager.checkPermission(SecurityManager.java:549)
at com.sun.javaws.security.JavaWebStartSecurity.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPropertyAccess(SecurityManager.java:1294)
at java.lang.System.getProperty(System.java:717)
at com.eteks.sweethome3d.swing.SwingTools.getResolutionScale(Unknown Source)
at com.eteks.sweethome3d.swing.ScaledImageComponent.<clinit>(Unknown Source)
... 34 more
It seems to be something with security, do not know how to proceed from here.
Thanks in advance for your help!
