Print at Sep 6, 2026, 6:07:28 AM
Posted by mikedeplume at Apr 16, 2017, 3:01:37 PM
Re: Cannot create plan outline
Yes. And again after your question, just to be sure :). It is quite short. Walls (and plans and polylines) are drawn in sequence click move click move click ... double click to end. It is also possible to press enter to end the sequence and bring up a properties box. Alternatively, pressing Esc after a single click abandons the current wall.
I'm sorry if my original post was not clear on that but I was trying to point out that, during the 'move' part of the sequence the item being drawn simply fades away. If I do click move click move and so on I get a new wall started at each click, and each new wall fades away as I draw it during the 'move' phase and before the subsequent click. My previous post was meant to indicate that, under some some circumstances I can be very lucky and actually manage to complete a very short wall. It is not reproducable, and I have no control over the length of wall.
I can add that each wall starts off following the mouse closely, but it then stops extending, while the mouse pointer continues to move. Once it has stopped it fades away. It occurs to me that it is similar to what might happen if you press Esc., but I'm not pressing Esc.
Have I understood the manual correctly? Is there some property that might upset the process? Is there some way that the Esc process can be triggered?
