Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: ALERT : Win10 build 1703 » » » » Post: Re: ALERT : Win10 build 1703 |
Print at Jul 27, 2026, 7:35:15 PM |
| Posted by Puybaret at Apr 12, 2017, 11:54:53 AM |
Re: ALERT : Win10 build 1703 It looks like the Java bug #8170517 or #8173471. The first one was closed as non-reproducible and the second one was resolved recently but the fix is probably not published yet. The bug must happen as soon as you try to access a file dialog box to choose a sh3d file or any other file handled by Sweet Home 3D, with a problem to access this file. To cancel the directories that you used recently in Sweet Home 3D, run regedit, search for last/Directory# and last/Default/Directory in folders ending with com/eteks/sweethome3d and remove matching entries. If it doesn't work better after that, try to move and open a Sweet Home 3D file in a very common place like your desktop to check if it works better or not. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Jul 27, 2026, 7:35:15 PM |
