Print at Aug 20, 2026, 1:52:30 PM
Posted by bdfd at Mar 29, 2017, 8:20:53 AM
Re: Home Cinema
Hi
Did you mean something like this if you did then you can get the sh3d file from here from it you should be able to figure out the walls and floors, each "step" is a room created in the individual area then exported and imported as an object. the beauty of using rooms in this way is that its shape, when drawn freehand is limited only by your imagination, or you can, as i did create walls any angle or arc, create a room in it then delete the walls.
Hope this helps, great idea doing a cinema, good luck
@miker, are you in holydays ? laughing
Because your model 3D is really perfect ! wink
