Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Two-Story Double Jack-and-Jill Home » » » » Post: Re: Two-Story Double Jack-and-Jill Home |
Print at Sep 28, 2026, 10:36:09 AM |
| Posted by AeowynFraser at Mar 15, 2017, 9:51:58 AM |
Re: Two-Story Double Jack-and-Jill Home It's been a while, as I was working on a sewing project, but I've been able to get rendered pictures of the first floor rooms. Here's the area in front of the elevator. It's actually wider than it seems, as it measures about 6 feet by 12 feet. You can see the bit of hallway leading to the first set of rooms. There's a window just over the virtual visitor's right shoulder, and a small one hidden behind the elevator. The enclosed balcony area, taken from in front of the doors to the stairs. Since this is on a separate file from the master file, I had to come up with a way to make it look like it's not on the ground floor, so I put two flat giant boxes outside painted with the cloudy sky. Unfortunately, in doing so, the area was rendered quite dark. That dark strip visible in the first window on the right is the part of the elevator shaft that sticks out from the rest of the building. Screenshot of the enclosed balcony, to better see the furnishings. Room 101. As you can see I've made it a single occupancy room (just so you know, the odd numbered rooms are made up as single occupancy and the even numbered ones are double occupancy, with the suites being the exception). Going from left to right: dresser next to the door with a television on top (visible in the full length mirror), small table and chair in the corner, the twin bed and nightstand, full length mirror, bathroom door, extra chair (vaguely visible bottom right), and closet. Room 101's bathroom, taken from the door. The toilet is just out of visual bottom right. Also not visible is the shower head in the shower area, behind the shower curtain (and yes that is the same pattern as on the comforter and pillow shams in the room). Room 102... And as I take a closer look at this picture I can see a small error in the wall paint (visible in the full length mirror). I'll take care of that shortly. Also going from left to right: bathroom door, closet, full size bed with nightstands, full length mirror, double wide dresser with a television on top. I didn't take a picture of Room 102's bathroom. It's very similar to Room 101's bathroom, except the sink is on the opposite wall and out of visual. A picture wouldn't show much. I also didn't take pictures of the bathrooms to Rooms 104 and 106 for the same reason. Room 103. Same layout as Room 101, just different colors. Room 103's bathroom. Same as Room 101's, different colors. Room 104. Same basic layout as Room 102 but of course different colors, and no window. Room 105. Once again, same layout as Rooms 101 and 103, different colors, but this one had the window. And I just noticed that the dresser rendered badly. ![]() Room 105's bathroom. Room 106. The Suite (Room 107). Double occupancy, but the layout is different from the other double occupancy rooms; the bed is queen size. Going from left to right: bathroom door, television stand, double closets, bed and nightstands, double dresser (which I see rendered badly). The Suite's bathroom, the first picture taken from the door, the second taken from the corner near the shower stall. I'll try and take pictures of the second floor soon, but only of the balcony, The Suite, and possibly the Suite's bathroom, only because the rest of the rooms are just like their counterparts on this floor. ![]() I could keep the rooms varied in color as I do, or I could make them be all the same - in which case I'd have to choose which one color scheme to use. What do you think? ---------------------------------------- ![]() |
Current timezone is GMT Sep 28, 2026, 10:36:09 AM |
