Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Problem with wall thikness and room surfaces. » » » » Post: Re: Problem with wall thikness and room surfaces. |
Print at Oct 1, 2026, 7:59:19 PM |
| Posted by DoubleHP at Mar 3, 2017, 1:43:52 PM |
Re: Problem with wall thikness and room surfaces. Puybaret had not tried that, but, does not fix any of my issues. WAlls are not magnetic to rooms in any way (neither middle or sides of wall). It's PITA to draw a thick wall aligned correctly to room borders. Lack of magnetism means huge amount of mistakes every where (several cm wrong per item). Impossible to break the side of a room to add a feature. In short: draw a room, set walls around it, remove the room, create a room with double click, the surface value is different. |
Current timezone is GMT Oct 1, 2026, 7:59:19 PM |
