Print at Sep 15, 2026, 9:10:29 AM
Posted by Puybaret at Feb 27, 2017, 9:48:31 PM
Re: Power of html5-View?
Thanks for showing your work :-)
As explained in this thread, the home files created with the Export to HTML5 plug-in contain a Home.xml entry that respects this DTD. This XML file stores the 3D models, texture images and icons used by furniture and other objects in the attributes named model, icon, planIcon and image. The value of this attribute can be a file stored in the same ZIP file as Home.xml (for example "4/model.obj"), or a URL of a file stored on the same server as the ZIP file (security might prevent to reference a file on another server). This URL can reference directly a file like in
http://www.sweethome3d.com/textures/eteks-scopia/brown-cercles.png
or reference a file within a zip file like
jar:http://www.sweethome3d.com/models/contributions/batterie.zip!/batterie.obj
when it starts with jar: (the previous URL references the file batterie.obj in the ZIP file http://www.sweethome3d.com/models/contributions/batterie.zip).
Hope this can help you to organize your data.
