Print at Sep 20, 2026, 9:15:39 PM
Posted by Pixelwizard at Feb 27, 2017, 1:41:11 PM
Background Image wrong Scaling
i just discoverd an issue...it's very irritating. actually i rebuild a skyscraper ;) i have a very good floorplan and other informations to create a very precise construction. but the scaling of the imported background-picture ist wrong. while the x-dimension is almost perfect, the y-dimension does not fit in anyway. i checked the image with photoshop and did some measurements. the base layout of the building and plan is a square - so it should be easy. any distance measured in ps is fine and identical where it must be. could it be that for some reason the dpi's of the floorplan cause this issue? actually th jpg has 200dpi - should i increase to 300 or decrease to 72dpi? or 96dpi? i can work for the outer elements just by creating groups, copy, paste and turn. but the inner structure will be hard to create this way...especially because there are some levels with the same core but a different layout.
any ideas?
WIN10 Pro 64bit * 16 GB RAM * AMD FX 6100 * Geforce GTX 660
