Print at Sep 6, 2026, 5:20:47 AM
Posted by libnoon at Feb 26, 2017, 10:22:45 AM
Getting ready for Java 9
Hello,
Java provides a migration guide to Java 9.
FYI I have tried running the checking tools (jdeps for dependencies, jdeprscan for deprecated APIs).
Here are the results of jdeprscan. I have shortened the deprecated methods for brevity.
+ jdeprscan --class-path /home/noon/Downloads/softs/SweetHome3D-5.4/lib/SweetHome3D.jar:/home/noon/Downloads/softs/SweetHome3D-5.4/lib/Furniture.jar:/home/noon/Downloads/softs/SweetHome3D-5.4/lib/Textures.jar:/home/noon/Downloads/softs/SweetHome3D-5.4/lib/Help.jar:/home/noon/Downloads/softs/SweetHome3D-5.4/lib/iText-2.1.7.jar:/home/noon/Downloads/softs/SweetHome3D-5.4/lib/freehep-vectorgraphics-svg-2.1.1b.jar:/home/noon/Downloads/softs/SweetHome3D-5.4/lib/sunflow-0.07.3i.jar:/home/noon/Downloads/softs/SweetHome3D-5.4/lib/jmf.jar:/home/noon/Downloads/softs/SweetHome3D-5.4/lib/batik-svgpathparser-1.7.jar:/home/noon/Downloads/softs/SweetHome3D-5.4/lib/java3d-1.6/j3dcore.jar:/home/noon/Downloads/softs/SweetHome3D-5.4/lib/java3d-1.6/j3dutils.jar:/home/noon/Downloads/softs/SweetHome3D-5.4/lib/java3d-1.6/vecmath.jar:/home/noon/Downloads/softs/SweetHome3D-5.4/lib/java3d-1.6/gluegen-rt.jar:/home/noon/Downloads/softs/SweetHome3D-5.4/lib/java3d-1.6/jogl-java3d.jar:/home/noon/Downloads/softs/SweetHome3D-5.4/jre8/lib/javaws.jar lib/SweetHome3D.jar lib/Furniture.jar lib/Textures.jar lib/Help.jar lib/iText-2.1.7.jar lib/freehep-vectorgraphics-svg-2.1.1b.jar lib/sunflow-0.07.3i.jar lib/jmf.jar lib/batik-svgpathparser-1.7.jar lib/java3d-1.6/j3dcore.jar lib/java3d-1.6/j3dutils.jar lib/java3d-1.6/vecmath.jar lib/java3d-1.6/gluegen-rt.jar lib/java3d-1.6/jogl-java3d.jar
Deprecated methods (collected here as there are a lot of occurrences):
[...] deprecated method: java/awt/Component::minimumSize()Ljava/awt/Dimension;
[...] deprecated method: java/awt/Component::preferredSize()Ljava/awt/Dimension;
[...] deprecated method: java/awt/Component::reshape(IIII)V
[...] deprecated method: java/awt/Component::size()Ljava/awt/Dimension;
[...] deprecated method: java/awt/Container::countComponents()I
[...] deprecated method: java/awt/Container::insets()Ljava/awt/Insets;
[...] deprecated method: java/awt/event/InputEvent::getModifiers()I
[...] deprecated method: java/awt/Graphics::getClipRect()Ljava/awt/Rectangle;
[...] deprecated method: java/awt/List::addItem(Ljava/lang/String;I)V
[...] deprecated method: java/awt/List::addItem(Ljava/lang/String;)V
[...] deprecated method: java/awt/List::delItem(I)V
[...] deprecated method: java/awt/Toolkit::getFontMetrics(Ljava/awt/Font;)Ljava/awt/FontMetrics;
[...] deprecated method: java/awt/Window::hide()V
[...] deprecated method: java/awt/Window::show()V
[...] deprecated method: java/io/DataInputStream::readLine()Ljava/lang/String;
[...] deprecated method: java/io/File::toURL()Ljava/net/URL;
[...] deprecated method: java/lang/Boolean::<init>(Ljava/lang/String;)V
[...] deprecated method: java/lang/Boolean::<init>(Z)V
[...] deprecated method: java/lang/Byte::<init>(B)V
[...] deprecated method: java/lang/Character::<init>(C)V
[...] deprecated method: java/lang/Double::<init>(D)V
[...] deprecated method: java/lang/Double::<init>(Ljava/lang/String;)V
[...] deprecated method: java/lang/Float::<init>(D)V
[...] deprecated method: java/lang/Float::<init>(F)V
[...] deprecated method: java/lang/Float::<init>(Ljava/lang/String;)V
[...] deprecated method: java/lang/Integer::<init>(I)V
[...] deprecated method: java/lang/Integer::<init>(Ljava/lang/String;)V
[...] deprecated method: java/lang/Long::<init>(J)V
[...] deprecated method: java/lang/Long::<init>(Ljava/lang/String;)V
[...] deprecated method: java/lang/Package::getPackage(Ljava/lang/String;)Ljava/lang/Package;
[...] deprecated method: java/lang/Short::<init>(S)V
[...] deprecated method: java/lang/Thread::stop()V
[...] deprecated method: java/net/MulticastSocket::setTTL(B)V
[...] deprecated method: javax/swing/JComponent::reshape(IIII)V
[...] deprecated method: javax/swing/JList::getSelectedValues()[Ljava/lang/Object;
[...] deprecated method: javax/swing/text/JTextComponent::viewToModel(Ljava/awt/Point;)I
Jar file lib/SweetHome3D.jar:
class com/eteks/sweethome3d/swing/PlanComponent uses deprecated class javax/swing/JApplet
Jar file lib/Furniture.jar:
Jar file lib/Textures.jar:
Jar file lib/Help.jar:
Jar file lib/iText-2.1.7.jar:
Jar file lib/freehep-vectorgraphics-svg-2.1.1b.jar:
class org/freehep/graphicsio/gif/GIFImageWriterSpi uses deprecated field javax/imageio/spi/ImageWriterSpi::STANDARD_OUTPUT_TYPE
class org/freehep/graphicsio/ppm/PPMImageWriterSpi uses deprecated field javax/imageio/spi/ImageWriterSpi::STANDARD_OUTPUT_TYPE
class org/freehep/graphicsio/raw/RawImageWriterSpi uses deprecated field javax/imageio/spi/ImageWriterSpi::STANDARD_OUTPUT_TYPE
Jar file lib/sunflow-0.07.3i.jar:
Jar file lib/jmf.jar:
class com/sun/media/ui/BufferedPanel overrides deprecated method java/awt/Component::reshape(IIII)V
class com/sun/media/ui/BufferedPanelLight overrides deprecated method java/awt/Component::reshape(IIII)V
class com/sun/media/ui/ColumnList overrides deprecated method java/awt/Component::isFocusTraversable()Z
Jar file lib/batik-svgpathparser-1.7.jar:
Jar file lib/java3d-1.6/j3dcore.jar:
class javax/media/j3d/J3DGraphics2DImpl overrides deprecated method java/awt/Graphics::getClipRect()Ljava/awt/Rectangle;
Jar file lib/java3d-1.6/j3dutils.jar:
class com/sun/j3d/utils/applet/JMainFrame$1 uses deprecated class java/applet/Applet
class com/sun/j3d/utils/applet/JMainFrame implements deprecated interface java/applet/AppletStub
class com/sun/j3d/utils/applet/JMainFrame implements deprecated interface java/applet/AppletContext
class com/sun/j3d/utils/applet/JMainFrame uses deprecated class java/applet/AppletStub
class com/sun/j3d/utils/applet/JMainFrame uses deprecated class java/applet/AppletContext
class com/sun/j3d/utils/applet/JMainFrame has field named applet of deprecated type Ljava/applet/Applet;
class com/sun/j3d/utils/applet/JMainFrame has method named <init> having deprecated parameter type Ljava/applet/Applet;
class com/sun/j3d/utils/applet/JMainFrame has method named build having deprecated parameter type Ljava/applet/Applet;
class com/sun/j3d/utils/applet/JMainFrame has method named getAppletContext having deprecated return type Ljava/applet/AppletContext;
class com/sun/j3d/utils/applet/JMainFrame has method named getAudioClip having deprecated return type Ljava/applet/AudioClip;
class com/sun/j3d/utils/applet/JMainFrame has method named getApplet having deprecated return type Ljava/applet/Applet;
class com/sun/j3d/utils/applet/JMainFrame has method named access$000 having deprecated return type Ljava/applet/Applet;
class com/sun/j3d/utils/applet/MainFrame$1 uses deprecated class java/applet/Applet
class com/sun/j3d/utils/applet/MainFrame implements deprecated interface java/applet/AppletStub
class com/sun/j3d/utils/applet/MainFrame implements deprecated interface java/applet/AppletContext
class com/sun/j3d/utils/applet/MainFrame uses deprecated class java/applet/AppletStub
class com/sun/j3d/utils/applet/MainFrame uses deprecated class java/applet/AppletContext
class com/sun/j3d/utils/applet/MainFrame has field named applet of deprecated type Ljava/applet/Applet;
class com/sun/j3d/utils/applet/MainFrame has method named <init> having deprecated parameter type Ljava/applet/Applet;
class com/sun/j3d/utils/applet/MainFrame has method named build having deprecated parameter type Ljava/applet/Applet;
class com/sun/j3d/utils/applet/MainFrame has method named getAppletContext having deprecated return type Ljava/applet/AppletContext;
class com/sun/j3d/utils/applet/MainFrame has method named getAudioClip having deprecated return type Ljava/applet/AudioClip;
class com/sun/j3d/utils/applet/MainFrame has method named getApplet having deprecated return type Ljava/applet/Applet;
class com/sun/j3d/utils/applet/MainFrame has method named access$000 having deprecated return type Ljava/applet/Applet;
class com/sun/j3d/utils/behaviors/picking/PickMouseBehavior uses deprecated class java/awt/Event
class com/sun/j3d/utils/pickfast/behaviors/PickMouseBehavior uses deprecated class java/awt/Event
class com/sun/j3d/utils/picking/behaviors/PickMouseBehavior uses deprecated class java/awt/Event
Jar file lib/java3d-1.6/vecmath.jar:
Jar file lib/java3d-1.6/gluegen-rt.jar:
class com/jogamp/common/util/JogampVersion uses deprecated field java/util/jar/Attributes$Name::IMPLEMENTATION_URL
class com/jogamp/common/util/JogampVersion uses deprecated field java/util/jar/Attributes$Name::IMPLEMENTATION_VENDOR_ID
Jar file lib/java3d-1.6/jogl-java3d.jar:
class com/jogamp/nativewindow/awt/JAWTWindow uses deprecated class java/applet/Applet
class com/jogamp/opengl/awt/GLCanvas overrides deprecated method java/awt/Component::reshape(IIII)V
class com/jogamp/opengl/awt/GLJPanel overrides deprecated method javax/swing/JComponent::reshape(IIII)V
class jogamp/opengl/awt/VersionApplet extends deprecated class java/applet/Applet
class jogamp/opengl/awt/VersionApplet uses deprecated class java/applet/Applet
