Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Different '3D view' rendering qualities to accommodate different... » » » » Post: Re: Different '3D view' rendering qualities to accommodate different... |
Print at Sep 15, 2026, 7:11:01 AM |
| Posted by Puybaret at Feb 20, 2017, 11:43:01 AM |
Re: Different '3D view' rendering qualities to accommodate different... A plug-in won't let you replace a 3D factory by another one. The default Ant target of Sweet Home 3D project builds an executable Jar, so once you downloaded its source code, open it with Eclipse, change the few lines in program you noticed, just select the Run As > Ant Build menu item in the contextual menu of build.xml. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 15, 2026, 7:11:01 AM |
