Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Copy / paste furniture stopped working after upgrade to 5.3 » » » » Post: Re: Copy / paste furniture stopped working after upgrade to 5.3 |
Print at Aug 21, 2026, 2:53:02 AM |
| Posted by okh at Feb 15, 2017, 9:22:34 AM |
Re: Copy / paste furniture stopped working after upgrade to 5.3 must be this second operation that may be too long, and I wonder if I shouldn't make it work differently, at least with a waiting screen. It makes sense that could be the reason. I could be wrong, but it seems that the larger the area (in m²) that is copied, the longer it takes. Tried some more: - a simple lake <3KB .obj scaled to 10000×6000cm took very long, - copying the entire terrain level 10000×10000cm appeared to not work at all, - while a small room with lots of furniture was reasonably quick. I think, btw, that Ceciliabr has mentioned something similar in a previous thread discussing landscapes and perspectives. However, I hasten to add that the extra image that can be pasted into other software is very clever. For anyone wanting to present a project, pasting the plan images is super convenient. So personally, I would rather suffer slow copying than loose picture generation altogether. Maybe: - waiting screen, - toggle image-function on-off, - warning when copying large areas (similar to texture import), Feature request (817) submitted - even if it is probably not very important (What is priority 1? Highest or lowest? I never dare change the priority as it may seem impatient... ). Also saved example file should you need to test it. ok |
Current timezone is GMT Aug 21, 2026, 2:53:02 AM |
