Print at Aug 13, 2026, 8:56:42 PM
Posted by Miker777 at Feb 10, 2017, 5:24:45 PM
Re: Modifying Staircase to Prevent Floor Hole
Hi Anatosuchus.
I recently had a similar issue, and, like yourself, wanted to find a way to use the staircase even though the holes generated in the 1st and 2nd floors were huge. What i did was to create rooms to the shape of the area needed, then exported and imported it, once positioned (magnetism off) i reduced its thickness by 50%, copied and pasted another and positioned it in exactly the same position, with that done i then raised 1 of them, so the two appeared laminated, textured the upper 1 to match my floor and the lower 1 to match the ceiling below.
Hope this helps.
