Print at Jul 22, 2026, 8:22:37 AM
Posted by Ceciliabr at Jan 14, 2017, 2:19:18 PM
Re: Some trees & stuff – sharing some of my larger exterior models.
@VeroniQ
Yes, these are models and textures I have created using combinations of different designer software and my own photographs.
The trees and the plants are created with Eon Vue and re-textured in Photoshop, rocks and grass are created with Poser Pro. The terrain is generated from a handcrafted heightfield map.
The ground texture is created with various brushes in Photoshop, and is meant as an alternative to the tiled lawns. I have reduced the size to 1,4Mb. The resolution is 4096 x 4096, and it gives the best result if sized between 100 x 100 and 200 x 200 meters.
You can of course use everything as you please.
