Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: textures are displayed very dark » » » » Post: Re: textures are displayed very dark |
Print at Aug 20, 2026, 9:01:21 AM |
| Posted by Puybaret at Jan 5, 2017, 3:41:57 PM |
Re: textures are displayed very dark From the screen capture and the message he posted, Martin complains about the brightness in the 3D view, not with SunFlow. It's the same old story about Why my wall isn't white whereas I selected a white color?, but this time, with textures. And the answer is the same: if everything was white, you wouldn't distinguish the corners of the room anymore (even if it's less true because of the pattern of the texture would help). Anyway, check the walls around you (moreover in winter): are they really the same color/brightness on every wall? Aren't the walls brighter close to light sources or windows? As suggested by bdfd and VeroniQ, if you want to control better the lights, you should use the photo creation tool at the two best quality levels. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 20, 2026, 9:01:21 AM |
