Print at Sep 29, 2026, 2:51:40 PM
Posted by rpax at Dec 6, 2016, 9:05:36 PM
Re: SweetHome3D-5.3 gives 3D error on Ubuntu 16.04 with updated Nvidia driver (375.20)
Seems to be a problem with the onscreen rendering.
I'm Using Ubuntu 16.04.1 LTS 64-bit, and an NVIDIA Quadro K2100M.
It gives me the following error:
com.jogamp.opengl.GLException: J3D-Renderer-1: Error making temp context(1) current: display 0x7f73c0196160, context 0x7f73c01a78d0, drawable X11OnscreenGLXDrawable[Realized true,
Factory jogamp.opengl.x11.glx.X11GLXDrawableFactory@8feadc3,
Handle 0x480009b,
Surface JAWTWindow[0x1bc19888][JVM version: 1.8.0_111 (1.8.0 update 111)
JAWT version: 0x10004, CA_LAYER: false, isLayeredSurface false, bounds [ 0 / 0 749 x 373 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], pixelScale 1.0x1.0, shallUseOffscreenLayer false, isOffscreenLayerSurface false, attachedSurfaceLayer 0x0, windowHandle 0x480009b, surfaceHandle 0x480009b, bounds [ 0 / 0 749 x 373 ], insets [ l 0, r 0 - t 0, b 0 - 0x0], window [0/0 749x373], pixels[scale 1.0, 1.0 -> 749x373], visible true, lockedExt false,
config AWTGraphicsConfiguration[AWTGraphicsScreen[AWTGraphicsDevice[type .awt, connection :0.0, unitID 0, awtDevice X11GraphicsDevice[screen=0], handle 0x0], idx 0],
chosen GLCaps[glx vid 0x72, fbc 0x189: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]],
requested GLCaps[rgba 5/5/5/1, opaque, accum-rgba 0/0/0/0, dp/st/ms 16/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]],
X11GraphicsConfig[dev=X11GraphicsDevice[screen=0],vis=0x72],
encapsulated X11GLXGraphicsConfiguration[X11GraphicsScreen[X11GraphicsDevice[type .x11, connection :0, unitID 0, handle 0x7f73c0196160, owner true, JAWTToolkitLock[obj 0x3f6b4a2c, isOwner true, <bc669e9, 762b4de7>[count 1, qsz 0, owner <J3D-Renderer-1>]]], idx 0], visualID 0x72, fbConfigID 0x189,
chosen GLCaps[glx vid 0x72, fbc 0x189: rgba 8/8/8/8, opaque, accum-rgba 16/16/16/16, dp/st/ms 24/0/0, dbl, mono , hw, GLProfile[GL4bc/GL4bc.hw], on-scr[.]]]],
awtComponent com.eteks.sweethome3d.j3d.Component3DManager$ObservedCanvas3D[canvas2,0,0,749x373],
surfaceLock <77ba2b41, 11e94f54>[count 1, qsz 0, owner <J3D-Renderer-1>]]]
at jogamp.opengl.x11.glx.X11GLXContext.createImpl(X11GLXContext.java:393)
at jogamp.opengl.GLContextImpl.makeCurrentWithinLock(GLContextImpl.java:765)
at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:648)
at jogamp.opengl.GLContextImpl.makeCurrent(GLContextImpl.java:586)
at javax.media.j3d.JoglPipeline.createNewContext(JoglPipeline.java:6411)
at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:4602)
at javax.media.j3d.Canvas3D.createNewContext(Canvas3D.java:2376)
at javax.media.j3d.Renderer.doWork(Renderer.java:881)
at javax.media.j3d.J3dThread.run(J3dThread.java:271)
Try setting the flag
-Dcom.eteks.sweethome3d.j3d.useOffScreen3DView=true
. It should work.
@Puybaret: Debugging a little bit, seems that something is messed up in the interaction between the creation of the 3D Canvas and the new java3D libraries. I'll take a closer look at
Best,
-.Rafael.
