Print at Aug 25, 2026, 7:18:10 AM
Posted by Jaulschge at Dec 2, 2016, 12:07:07 PM
confused   Problem with importing an specific OBJ file
Hello,
We hope anyone can help us with our problem. We do use a software called "PX'5" to export 3D-models into the FBX format.
We then wanted to use the Autodesk FBX Converter to convert the FBX files into an OBJ file.
It works to this step without problems. OBJ/MTL file is generated successfully.
But If we then try to import this OBJ file into SH3D it gives me the error message, that the file is not supported ("Das gewählte Format wird nicht unterstützt. Bitte wählen Sie eine andere Datei.)
Is there anything we need to pay attention to, when creating the FBX file/Converting the FBX file?
Our goal is to use the SH3D Export to HTML5 plugin at the end, to publish the models to a website.
Any help would be much appreciated. Thank you.
