Print at Sep 14, 2026, 3:24:04 PM
Posted by Puybaret at Nov 19, 2016, 6:00:46 PM
Re: Custom furniture catalog?
The Online version doesn't allow to copy items between two open windows.
But within the same window, it's possible to copy-paste items from a home to the other:
- open the home from which you want to transfer some items
- select the items you want in the plan or in the furniture list and choose Copy in the contextual menu of the plan or the furniture list
- open the home into which you want to paste the items
- click in the plan or in the furniture list to give it the focus, and select Paste in its contextual menu.
To help you select the items you want to copy more easily, keep in mind that each piece of furniture in Sweet Home 3D is movable or not. To select only movable furniture, choose the Display column > Movable menu item in the contextual menu of the furniture list, then click on the header of the Movable column to sort the column on this criterion. Et voilĂ ! You can easily select only the movable items in the first part of the list wink
