Print at Sep 30, 2026, 9:50:22 PM
Posted by Miker777 at Oct 25, 2016, 12:55:19 AM
Re: Walls not vertically but under 75 degrees
Hi HobbyBouwer
If you position the walls you require, add windows, doors etc, then export it, on importing you could tip it to 75 degrees. If you do not require doors or windows, then i would suggest using the shape generator, this would enable to create a rhombus, keeping top and bottom surfaces horizontal.
Hope this helps.
