Print at Sep 30, 2026, 1:41:02 PM
Posted by Puybaret at Sep 26, 2016, 5:24:12 PM
Re: How to update furniture within a scene after applying changes to the model?
You can't make that kind of change from Sweet Home 3D user interface.
But as .sh3d files are actually simple zip files, you can explore them and replace the 3D models found in the subfolders of such .sh3d files by other ones, as long as you keep the same file name for .obj, .dae and .3ds files. Before saving, you should also remove the file named ContentDigests otherwise Sweet Home 3D will refuse your new model.
Of course, if you try this way, I encourage you to backup your .sh3d files before doing such changes, to avoid losing your work.
