Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Sloping ceiling over 2 floors possible? » » » » Post: Re: Sloping ceiling over 2 floors possible? |
Print at Oct 6, 2026, 8:41:41 AM |
| Posted by okh at Sep 12, 2016, 10:02:08 AM |
Re: Sloping ceiling over 2 floors possible? You may want to share a plan to illustrate your question, but from what you say, it sounds as if you may have to use another set of sloping walls on the second level. However, ceilings can be a bit tricky with sloping walls, so it is usually easier and beter to disable ceilings under sloping walls and use a roof with an underside to see the ceiling (putting the roof/ceiling on a separate level makes it easy to toggle visibility of ceiling/roof). But I may well misunderstand your problem. Possibly these two blog posts can be of help: how_to_design_a_sloping_ceiling_with_a_window how_to_design_a_mezzanine ok |
Current timezone is GMT Oct 6, 2026, 8:41:41 AM |
