Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Can't import OBJ filed with textures » » » » Post: Re: Can't import OBJ filed with textures |
Print at Sep 20, 2026, 2:16:32 AM |
| Posted by hansmex at Aug 9, 2016, 3:12:15 PM |
Re: Can't import OBJ filed with textures The OBJ file contains an address where it can find the MTL directory. When you move the OBJ file, you should also move the MTL file. 1 - If OBJ and MTL are in the same directory, they should stay in the same directory. 2 - If the OBJ is in parent directory and MTL is in parent/textures directory, and you move the OBJ file to model directory, then the MTL should move to model/textures directory. ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 20, 2026, 2:16:32 AM |
