Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Heights and elevations » » » » Post: Re: Heights and elevations |
Print at Sep 6, 2026, 5:36:22 AM |
| Posted by UKenGB at Jul 24, 2016, 11:37:50 AM |
Re: Heights and elevations Thanks for that Hawk, the width is as I surmised, but good to have confirmation. While on the subject of doors and windows though, what does the 'keep proportions' checkbox do? Doesn't seem to make any difference and is unset when I check again. I thought it meant maintain the same ratios, but I tried it with the cylinder and could still drag the circle into an ellipse so looks like I'm not right about that. What should one do about a threshold for a door? They don't seem to include one, but external doors really need one. Is there some standard way to add one that I'm missing? Another problem I'm having with doors is the side on which they are hung. They flip between opening in or opening out, but always also hinge on that side. I want a door that opens in, but is hung on the outer edge of the wall. Is this something that can be set, or do I need to choose a different door object? Also I'm using a window object that has large sill projections that protrude a long way out of the walls if I allow the object to snap-to the wall. Is this adjustable without manually reducing the depth of the window to less than that of the wall, or again, should I just find a different window object? |
Current timezone is GMT Sep 6, 2026, 5:36:22 AM |
