Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Show all levels at once in 2D? » » » » Post: Re: Show all levels at once in 2D? |
Print at Sep 27, 2026, 10:23:23 PM |
| Posted by okh at Jul 15, 2016, 11:47:50 AM |
Re: Show all levels at once in 2D? .. 2D diagram with dimensions to build a materials list. ...show all levels in one view?.. Hmm... Not sure what you are trying to do. You can set elevation of several levels to the same, and they will both display (unless hidden). You can cut and paste between levels - also dimension lines, polygons and comments. Or is it something else you are after?As for the furniture list bdfd is absolutely correct. But the easiest is probably to display the columns you want, sort them (all from the right-click contextual menu) select the items you want (click, shift/click, ctrl/click and select all provides options for items you wish to include) - and then copy and paste directly into a spreadsheet. Works pretty much the same as the csv export, but saves the detour of exporting. Either way you need to set the paste/import to tab delimited. ok |
Current timezone is GMT Sep 27, 2026, 10:23:23 PM |
