Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: DirectX driver issues in windows 10 » » » » Post: Re: DirectX driver issues in windows 10 |
Print at Aug 15, 2026, 9:50:04 PM |
| Posted by mpindado at May 9, 2016, 10:30:49 AM |
Re: DirectX driver issues in windows 10 Hi, I had the same problem on a windows 10 x64 system. This is how I finally solved it using java 64 bits: - Install Sweet Home 3D - Rename the jre8 folder in installation directory (C:\Program Files\Sweet Home 3D) to jre8.bak (JRE bundled is 1.8.0_74) - Install a previous JRE 64 bits (For me it worked with 1.8.0 and 1.7.X). It gets installed in c:/"Program Files"/Java/JREXXX - Either copy/mklink c:/"Program Files"/Java/JREXXX directory as C:\Program Files\Sweet Home 3D\jre8 This is another way of making it run without JNLP and java 32 bits: - Download and install java 32 bits - Download SweetHome3D jar from sourgeforge (https://sourceforge.net/projects/sweethome3d/...etHome3D-5.2.jar/download) - With only 32bits java installed, double click to start - With multiple java installed, create a start.bat file pointing at the correct java containing: C:/Program Files/java/JAVA-VERSION-WORKING/bin/java -jar C:/DIRECTORY-WITH-JAR/SweetHome3D-5.2.jar) |
Current timezone is GMT Aug 15, 2026, 9:50:04 PM |
