Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Is it possible to move levels? » » » » Post: Re: Is it possible to move levels? |
Print at Oct 21, 2026, 10:14:48 PM |
| Posted by Puybaret at Apr 5, 2016, 9:19:38 AM |
Re: Is it possible to move levels? The level modification dialog box lets you edit only the selected level and the up and down arrows are used to change the order of a level if it's at the same elevation as an other one. In your case, you need to change the elevation of a level, that's why you should select its tab at the top of the plan then modify the level to edit its elevation. Once done, repeat the operation for each level. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 21, 2026, 10:14:48 PM |
