Print at Sep 20, 2026, 6:37:01 AM
Posted by hansmex at Mar 31, 2016, 12:52:07 PM
Re: VERY slow video rendering
1 - If one image takes around one minute to render, than a 30 second video should take around 30x24 frames = 720 frames = 720 minutes = 12 hours.
My suggestion: give it a try and let your computer render overnight.
2 - If there are any objects/lights in your design that do not show up in the video, make them invisible.
Example: if you have five rooms, but only three appear in the video, make everything in the other two rooms invisible.
Example: if you show only the right side of a room, make everything on the left side invisible.
Reason: Everything in your design is taken into account when deciding if/how it should be rendered, regardless whether or not it appears in the image being rendered. Being invisible, objects are excluded from this braod sweep. This can potentially speed up rendering quite a bit.
