Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Tudor Castle version 2 » » » » Post: Re: Tudor Castle version 2 |
Print at Sep 23, 2026, 8:02:45 PM |
| Posted by AeowynFraser at Feb 29, 2016, 8:00:44 PM |
Re: Tudor Castle version 2 I've gotten the second floor done. Here's the bedroom marked as "Bedroom 1". You can see the edge of the closet on the right side of the picture. That little bit of wood visible in the bottom left corner is the dresser. The walls are supposed to be painted a light blue but for some reason the color is a bit washed out. ![]() Here's the bedroom marked as "Bedroom 2". Basically it's a mirror of Bedroom 1 but with different design choices. ![]() Main Bathroom. The toilet is just out of visual at the bottom left. And yes, the window is in the shower area, unfortunately. The walls are supposed to be a light green, complementary to the tiles; I might change that later. ![]() Laundry room. Not much to it. There are storage cabinets in the one corner; the knobs for them are visible. The walls are supposed to be a lighter color than the hallway but this picture didn't quite capture that. ![]() The Family room, as seen from the hallway. The wall color is supposed to be blue as well, but for some reason it looks green. ![]() The Family room, as seen from the doorway of Bedroom 3. ![]() Bedroom 3. There's another closet, the edge of which is just visible on the left side. I'm not quite satisfied with the layout of this room; I might change it later. ![]() The next two pictures are of the back of the house. I've added a small patio, making the roofing styled like two of the roofs in the front. I've also started painting the exterior, using the texture "Beige roughcast with white stones", as I worked on the different rooms on each floor. ![]() ![]() I'm thinking that maybe the patio area might be a bit narrow and I might change that later. Here's a view of the patio from the living room back door. This is still a work in progress as I haven't yet started working on the third floor. ---------------------------------------- ![]() |
Current timezone is GMT Sep 23, 2026, 8:02:45 PM |
