Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to creat two different textures on the same wall? » » » » Post: Re: How to creat two different textures on the same wall? |
Print at Oct 1, 2026, 7:59:50 PM |
| Posted by okh at Feb 23, 2016, 9:30:17 PM |
Re: How to creat two different textures on the same wall? Scaling images is in the material dialogue - modify texture (and dialogue you get when you import textures). But it may not work on all textures (not the ones from libraries that come with a set size). But it does work when you import textures. You cannot, however, change the proportions, only the scale. For more advanced editing, you need to use a graphics editor. A good hint is to stay with relatively small textures (< 512x512 pixels). ok PS - If you want to scale a texture with set size from a library, you can apply that texture to any object, select the object, use 3D view, Export to OBJ. Then the texture file will be saved as a separate file, and you can import that texture and scale it as much as you like. |
Current timezone is GMT Oct 1, 2026, 7:59:50 PM |
