Print at Sep 19, 2026, 6:56:59 PM
Posted by okh at Feb 18, 2016, 6:47:06 PM
Re: Landscaping
Well - there is sort of a disclaimer saying that SH3D is not really landscaping software. So do not expect it to happen automatically...
That said, it is possible to create a landscape around your creation. Exactly how, depends on whether you need a basement or not. It seems you are in an explorer phase - in which case you may not need to read on.
If you are not going to have a basement (negative elevation on the lowest levels), you can just use a triangle (or some other shape) for your terrain (giant triangle).
But a triangle will be visible in the lower levels, so if you need a basement, you need to put your triangles (or other shapes) AROUND the foundation to simulate the terrain.
Here is a, maybe not very elegant (but relatively simple), way of doing it: template_scandinavian.sh3d.
Note that you may want to play with levels (and in-between levels) in addition to some shapes (SF models 299 ) around the house.
