Print at Aug 12, 2026, 1:24:50 PM
Posted by Puybaret at Feb 10, 2016, 6:57:05 PM
Re: Visibilité du toit / hidden roof
It looks like the triangles that you use are single sided and the visible side is oriented towards the ground.
When you import them, you should select the option Invert back and front faces at the second step of Furniture import wizard. You could also use some double sided triangles or simply use this simple triangle that you'll resize.
