Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Library Editor won't run under Windows 10 » » » » Post: Re: Library Editor won't run under Windows 10 |
Print at Sep 9, 2026, 10:07:04 PM |
| Posted by hansmex at Feb 10, 2016, 3:37:22 PM |
Re: Library Editor won't run under Windows 10 C:\Users\Hans>java -jar C:\Users\Hans\Downloads\FurnitureLibraryEditor-1.18.jar feb 10, 2016 3:22:42 PM java.util.prefs.WindowsPreferences <init> WARNING: Could not open/create prefs root node Software\JavaSoft\Prefs at root 0x80000002. Windows RegCreateKeyEx(...) returned error code 5. @Emmanuel, Above what happens when I do as you told. Result: Library Editor starts correctly. THANK YOU !!! I have changed my *.bat script so that it includes the path to the file. Result: DOS window opens with same error message as above; Library Editor starts correctly. EDIT Indeed, I can import files in the Library Editor. Problem: ALL imported .zip files are called "Model", even when all file names are different. (= Scopia/Hausmann windows from 3D models page.) END EDIT @OK 1 - Extensions are visible for all files. I changed this a few weeks ago, and I re-checked today that I did it the correct way. 2 - If I download your example file, it is shown with the extension .sh3d. - If I double-click the file, SH3D opens and shows the design. - improved features? Only improved features in W10 are high blood pressure and bugs. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 9, 2026, 10:07:04 PM |
