Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Library Editor won't run under Windows 10 » » » » Post: Re: Library Editor won't run under Windows 10 |
Print at Sep 9, 2026, 10:07:04 PM |
| Posted by Puybaret at Feb 10, 2016, 2:39:03 PM |
Re: Library Editor won't run under Windows 10 Hans, please try to run the Editor from the command line: - run cmd - type java -jar and drag and drop FurnitureLibraryEditor-1.18.jar file in the command window to get its path - type <Enter>. If there's a problem, there should be some log that appears in the command window. Please report it here, so I can help you further. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 9, 2026, 10:07:04 PM |
