Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Possible to move an entire floor to align with another floor? » » » » Post: Re: Possible to move an entire floor to align with another floor? |
Print at Aug 17, 2026, 12:50:27 AM |
| Posted by okh at Feb 5, 2016, 9:27:42 PM |
Re: Possible to move an entire floor to align with another floor? Automatically, not as far as I know. Usually it is better to copy the outer walls between levels so they inherit the same co-ordinates. If you want to move (several walls/rooms/models), you should try out the Advanced Editing Plugin. However, it looks as if your walls are not the same dimensions, so just moving them, may not be sufficient. In that case it might be easier to delete everything on level 2 and just copy everything from level 1. May be easier than modifying each wall... ok |
Current timezone is GMT Aug 17, 2026, 12:50:27 AM |
