Print at Sep 20, 2026, 3:39:10 AM
Posted by digitaltrails at Jan 8, 2016, 6:47:52 AM
Re: Change color plugin
I've found one bug. The plugin can't change a color if it is the color of a material and it's the default material color. If you have already changed the material's color to something other than the default, the plugin will work.
I have a fix for this bug and will release it in the next few hours once I have tested it a bit more. The fix is to compare colors without the alpha component (only comparing RGB values). I should probably copy the alpha (transparency) from the from as well.
I should add I'm using OpenSuse Linux 13.1 64 bit and SH3D v5.1 64 bit with the JRE it was shipped with.
I'm using Java JDK 1.7 for development but the compiler is set to 1.6 compliance.
