Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Polylines 2d to solid 3d » » » » Post: Re: Polylines 2d to solid 3d |
Print at Sep 6, 2026, 8:18:44 AM |
| Posted by hansmex at Jan 5, 2016, 3:52:26 PM |
Re: Polylines 2d to solid 3d The feature you are looking for doesn't exist in SH3D. You can draw curved walls in SH3D to make the curved walls with holes in your picture. Use an invisible box (imported as door/window) and slide it into the wall using the arrow keys to make the cut-outs. You could experiment with curved walls as well to make the mouldings. - Draw a thin curved wall, just a few centimeters thick and high - Add additional walls that fit perfectly to build your moulding yourself. - When finished, select the end result, and export to OBJ format. - Import the model, rotate it and fit it at the correct elevation. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 6, 2026, 8:18:44 AM |
