Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Recent experiment » » » » Post: Re: Recent experiment |
Print at Sep 20, 2026, 12:18:24 AM |
| Posted by okh at Dec 11, 2015, 9:12:07 AM |
Re: Recent experiment PCjr. ![]() .. orthorectangular projection issues ... Yes, true it is hard to make it look good (see thread 5533 for sky projection). Simply put, the horizon needed a lot of sky above and only a thin stretch of ground view, and still only good on some locations (with a wide view)...it belongs more in the midground... ..something to do with relative elevation... Yes but just a little elevation, like lifting the plan a couple of metres up with terrain under, changes the perspective considerably. Still, sky texture should represent a view near the actual horizon. For closer items, the workaround is better. The biggest problem, I find, is that big exterior objects shifts the view angle in aerial view further back (even if that level is hidden), hence the use of a separate file. Then again, this is not the main purpose of SH3D - but still fun to play with to visualize a project. ok |
Current timezone is GMT Sep 20, 2026, 12:18:24 AM |
